visual styles wireframe
I created a filter to do the following:
Wall below is shown as solid black lines.
Wall above is shown as solid red lines.
The walls above were masking the wall below to avoid this I set my visual style to "wireframe".
Now some of the lines red lines are being masked by the black lines eventhough the black lines are the walls below. Why?
bjoern_teutriene
Unfortunatelly it depends on the drawing sequence. 😞 It may be helps you if you cut your walls to clipboard and paste them alligned to the same place.
Beste Grüße
Björn
Senior BiM Consultant bei
www.bimotion.de
E-Mail | LinkedIn | YouTube
Yes that's the only solution I came up with also.
