Visual Presentation using Revit
Paul.Lessa
Paul.Lessa
Good morning.
I've sent this to Autodesk but they requested me to send my questions to Revit Forum. Probably most of my questions are "attached" to my inexperience with Revit, so please be patience.
Please see attachments. One attachment shows how it looks using AutoCAD LT, and the other attachment shows the same job using Revit. My main concerns are noted on that attachment.
Is there anyway that I could improve the Revit attachment to look a little better?
Thank you very much for your time and patience,
Paul Lessa
shefypattambi
Did you try to change the extension line length and witness line length parameter of your dimension style in Revit ? it is available in the type properties of your Dimension system family.
Paul.Lessa
It worked. Thank you for the help.
Thank you,
Paul Lessa
HP Consulting Systems, Inc.
www.hptiltwall.com
561-809-1358
