Visibility issue
Visibility issue
Visibility issue
Dear All,
I am facing the issue in sheet extraction. There are two images I have attached. One is structural model. One is Architectural model in which structural model is linked. How can I remove the Beam to Floor connection line.
Structural model. Line is not visible.Structural model. Line is not visible.Architectural model. Line is visibleArchitectural model. Line is visible
ennujozlagam
the beam and floor should be in the same material (structure materials) and then use join geometry to cut. thanks
selmanyesil
Draw line and make it invisible for a filled/masking region.
Selman YEŞİL
Selman YEŞİL LinkedinYoutube
