Viewport Labels are Blank
I'm new to Revit, so I'm struggling with some viewport issues. I've done six other projects and the vieport labels show up just fine, but on this project, I can't get the viewport labels to show at all. All I see is blank lines where the labels should be attached. I'm sure there is a simple fix for this, but I can't figure it out with all the forums out there. See the attached picture.
gregamhale
Select the viewport and change the viewport type you are using. If you don't have other types created, then duplicate the one you have and edit the type properties, which you will be able to display the view title, scale, etc...
This is all I see when  I bring up the type properties. The only type offered is what is shown, being the "structural plan." Are there any more suggestions for what this could be?
gregamhale
Open a sheet view.  Within the sheet view, select the viewport.  You should then see your viewport properties in the properties palette.  The viewport type can then be change by selecting the type selector.  See attached image.
There aren't other types I can use and I can't make one that shows the title. In the window under title, it shows "none" and there are no other options. It makes me wonder if there is a setting for the project as a whole that doesn't allow it to be shown. See the picture. Thanks so much for your help.
gregamhale
My guess is that the viewport titles were purged from the project.  You can either create a new viewport title family and load it into the project or transfer viewport titles from another project.  I would suggest transferring them.
To transfer them from another project, follow these directions;
1) Open your project you want the viewport title loaded into
2) Open the project you want the viewport title transferred from
3) Switch back to your first project, then select the Manage Tab and "Transfer Project Standards"
4) Deselect all standards except for Viewport Types and select OK
5) Viewport types will now be transferred to your project and you should be able to select them from the type selector as directed previously
I hope that resolves your issue.  See attached image.
That's it! WOW! Thanks so much for your help on that. I never would have gotten that. Thanks again!
