View Range
View Range
jwheatley
View Range
jwheatley
I have linked CAD drawing that does not cut off at the view range established in m section views.  Any recommendations or has anyone else experienced this issue?  I can control the view by turning layers off but if I have a pipe run that beyonds the view range it shows the entire run.  Any help is greatly appreciated.
CoreyDaun
I believe that you have to import the CAD file into a Family, and then load that Family into the Project to get it to obey the Section's View Range.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Chris.Aquino
The process as mentioned can be found here:
http://revitclinic.typepad.com/my_weblog/2011/04/importing-3d-geometry-from-autocad-mep-into-revit-m...
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
