Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Vertical & horizontal grid bubbles
9 REPLIES 9
Message 1 of 10
JFN_KSH
1428 Views, 9 Replies
My company standards require 2 lines for the grid bubble (see attach image). The problem is when the grid line is horizontal it flips the text as well... is there a workaround?
Thanks!
9 REPLIES 9
Message 2 of 10
in reply to: JFN_KSH
Did you try shortning the lable extent in the grid bubble head family?
Message 3 of 10
CoreyDaun
There are two parameters being referenced here, right? Is there only one label with a break, or are there two separate label entities?
Message 4 of 10
JFN_KSH
in reply to: CoreyDaun
I've created 2 separate labels... Should I try a different approach?
Message 5 of 10
CoreyDaun
Combine the two into a single label. While editing the label, check the box for "Break" to have Revit automatically put them on two separate lines. I believe that this will make it "behave" more like you want it to.
Message 6 of 10
JFN_KSH
Where is that break box...? Can't find it... (see image)
Message 7 of 10
CoreyDaun
Click "Edit...", see image.
Message 8 of 10
JFN_KSH
I cannot check that box...???? Its "Uncheakable"....
Why? This ia a shared parameter I've created...
Message 9 of 10
CoreyDaun
Did you add the second parameter to the label? You have do that first, so that there is something to place a break between.
Message 10 of 10
JFN_KSH
That it! It work!!! (see image) Thanks for you're great help... Its very appreciated.Smiley Happy
