Using Extensions 2017
NERDASORUS
NERDASORUS
Hello
I have a question regarding the Use of Extensions To rebar Structural Elements , I have a Structural Template That has the rebar Numbered (00-01-11-...) so i downloaded some pics that have the shape and the dimensions on them and modified the equations for calculating the length of each bar ,everything works great ,but when i use Extensions to rebar it uses shapes with strange names that arent even on the template like "Standard -0-0-21" Or "Stirrup-135xR-135xR-31"
Question Is : how to make it use the rebar families that are on the template  ?
Thanks in Advance
Luiscko
The problem is that extension use its families, for this case you need to go preferencesdsa.PNG and then charge your families that you can use in Revit Extension or you modified the default families in Revit extension.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
