Using Dynamo to toggle VG on and off
chriskD6WP2
chriskD6WP2
I'm not familiar with Dynamo but can't you use it to program a "switch" to turn point clouds on/off in different views? I've asked this question before but all I got was it might be possible. Well, if it is, can anyone direct me to some reference material on how I would do this with Dynamo?
Basically, these are the steps I currently take to turn off/on a point cloud.
View tab, Visibility/Graphics, Point Clouds, Check show/hide point clouds in view, OK
Anyone?
EdwinG
chriskD6WP2
Is that a link?
chriskD6WP2
Nevermind, I got it. That's what I was looking for, thanks!
nbennett
This will only switch one way then you would have to change the "True/False" to the opposite in order to make it change back so it truly is not a "toggle". I have been trying for a while now to make a true toggle that a user would not have to modify in order to toggle a line type on and off but have yet to find a true "toggle" to change the "True/False" so that when the script runs again it will change the line type visibility back.
