Update model from Space Gass
jarrod_willhelme
jarrod_willhelme
Hi All,
I am having issues when converting between Revit and Space Gass.
I have a Revit model which I can send to Space Gass and everything works well, Space Gass can map the member sizes and materials ok but any changes to member sizes cannot be updated back into Revit.
The "Update model from Space Gass 14" option in the add-ins tab seems to work without throwing any errors but just gives me a message "0 Revit Elements updated".
I have tried with both physical and analytical elements in Revit, using the built in and custom mapping files, changing the member sizes in Space Gass to other sizes already in the model but nothing seems to work. I have the member types loaded into my Revit model and since Space Gass can understand what I'm trying to do I cannot for the life if me understand why it doesn't work the other way.
Thanks in advance
Tom_Kunsman
Unfamiliar with that program. By any chance did you reach out to technical support from Space Gass to see if they had any recommendations or workflows you could try?
Most structural engineering programs seem to not understand the analytical model from Revit.
