unhide hidden layers to revit via Query command
Message 1 of 15
hello guys
i'd like to  unhide  hidden layers ,,,, that i imported form autocad to revit  ,,,,,,
i hided  the layers via Query command
with my best regards
Replies (14)
Message 2 of 15
A_MAQ
HERE IS THE WAY
Autodesk Expert Elite
Message 3 of 15
@A_MAQ   ,,,,,  thanks alot for your solution ,,,,,,
Message 4 of 15
A_MAQ
You are welcome
Message 5 of 15
@A_MAQ   ,,,,  i'd like also to know how can i upload a video like this to autodesk forums ,,,, and how can i download it ,,,, to save it in my repository ?
Message 6 of 15
A_MAQ
you need to download screen cast tool for autodesk here in this Link
Message 7 of 15
@A_MAQ   i downloaded the screencast ,,,,  and  installed it ,,,,,  and made a video ,,,,,  then stoped recording and no thing  ,,,, the program always freezes after stop recording   ,,,  and there is no any icons to work through it in the program after recording   ,,,, what is the problem ?
Message 8 of 15
A_MAQ
you need to sign in in revit using the same account you are using in autodesk at the top right corner of the revit software
Message 9 of 15
@A_MAQ   i have already signed in ,,,,  but the problem still works ,,,,,  and the  [ screencast ] ,,,,, after recording form it ,,,,  there is not icons to work through it ,,,,,,,,
Message 10 of 15
A_MAQ
can you take a screen shot of the problem ?
Message 11 of 15
@A_MAQ
after i made a video ,,,,,  and click on stop button ,,,,  a window like that appears in screen shot appears ,,,,,  with no icons to work with ,,,,, and with no thing ,,,,  just that window ,,,,
the only thing you can do with that window is you can make a video forward or backward   ,,,,  by moving the play icon right and left  ,,,, and also the video was not playing ,,,,,
Message 12 of 15
A_MAQ
at lower right of the pic you can find save and upload your screen cast
Message 13 of 15
A_MAQ
does that solve your issue?
Message 14 of 15
@A_MAQ
i've discovered that the buttons are hidden behind the taskbar if you look at the attached picture ,,,,,  so i auto-hided the task bar and be able also to work with this screen ,,,,,  but it is bad that i can't mimimze that screen ,,,,  you can work on it as it is ,,,,,,
thanks in advance for you ,,,,
Message 15 of 15
A_MAQ
this also happens to me while using my laptop
best,
