unable to open templates
In my pc even though i try to open a Structural or any other template or even i want to start a new project in structural only Architectural Templates opens up.
Ahmed_Muharram
which revit version do you use?
what is the error coming up? could you share a screen shot
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
L.Maas
You should give more information, before we can assist you
Which Revit version are you using?
Which templates (names), where are they coming from (e.g. folder)?
What kind of errors/warnings are you receiving?
Can you upload some of those templates so we can check?
Are the templates for your Revit version suitable (2019 templates will not load in Revit 2018)?
Other relevant information?
Louis
Please mention Revit version, especially when uploading Revit files.
hmunsell
Do you have templates in your RVT Templates folder? There is no "Architectural" template. there is Commercial, Construction, Residential, etc...
  • C:\ProgramData\Autodesk\RVT 2020\Templates\US Imperial
if you only want to see the Architectural ribbon,
  • go to File > Options > User Interface
  • Check or unCheck the disciplines you want to see.
Howard Munsell
