Tube Steel Connections
I am new to using connection in Revit. I have been able to have success with standard W shape members. Looking for help on how to get tube steel to connection to each other. No matter the connection type I try and use I get an error/warning of invalid connection.
A_MAQ
Hi @Anonymous,
check This link
Autodesk Expert Elite
mihai.sandu
Hello Evan,
Connection macros are specific to section shapes.
If you want to connect 2 tube sections, to each other, you should use the Tube End to End. This available starting with Steel Connections for Revit 2018 version.
I also want to mention, that if you hover the mouse over a connection type, you will have a helping picture popping-up, with different situations in which you can use the connection type. There is also a Description bellow the picture, in which the possible section shapes are described.
Mihai Sandu
Sr. QA Analyst
