Triangular Shaped Stirrups
不适用
1,694 次查看
4 条回复
1 条消息(共 5 条)
不适用
Hi Everyone,
I want to add triangular shaped stirrups in revit, searched in all the available libraries but did not any relevant shape. Also, tried to create that shape by using default family template and getting some errors.
Attached is the desired shape.
0 个赞
1,695 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
ennujozlagam
hello, you can try model in-place use sweep or 2 sweep and use join geometry. thanks
0 个赞
3 条消息(共 5 条)
不适用
Thank you for your response, but as much i know structural rebars can not be created using model in place.
0 个赞
4 条消息(共 5 条)
EdwinG
Use Sketch rebar, after the sketch the shape is automatically added tot the rebar shape browser (bottom right on the pic)
-select rebar on the ribbon
-select sketch rebar
-Pick the element to rebar
-draw your shape
-hook at end, hook at start 135 deg.
-finish
5 条消息(共 5 条)
darmomin11
Community Visitor
Community Visitor
can u explain how made this rebar shape
0 个赞
