Text appears more spaced out in some text regions but not others
ahart6PQPL
Observer Observer
ahart6PQPL
Observer
Observer
See screen shot. Text on left has smaller intra-letter spacing than text on right even though all properties match. I have no idea why this is happening and I have tried all obvious fixes. I have used matchprop, manually verified type settings, reset fonts, etc. This shows up in PDF as well so its not just some weird artifact in revit.
rafael.marinGFHRP
Try copy-paste the text on the left and retype, maybe it properties stays and the intra-letter spacing stays the same, this worked for me with some rebar properties, maybe with text can work too!
jay_colcombe
I have noted this in previous Templates opened in newer version and when pasting text from an external source sometimes but when creating everything from new I cannot repeat so initially I thought it was text properties being carried over into Revit from original text formatting.
This may help a little as it does clearly show there is a difference between font styles but also there is a link at the bottom to a Revit Idea specifically relate to this topic.
Row spacing is not the same for all fonts in labels in Revit.
Jay Colcombe
Autodesk Certified Instructor
ahart6PQPL
Observer
Observer
Thanks for the response. It seems to be a per text box issue because when I copy the text from a "narrow font" text box into a "wide font" text box, it looks narrow until I exit the box then it jumps to wide.
I'm attaching a GIF where I show the text jumping from wide to narrow and back. Note that the text box type is the exact same.
