Subject: Need help with finding structural connections in Revit software 2024
adigasbhavana21
Message 1 of 10
adigasbhavana21
I hope this email finds you well. My name is Bhavana Adiga, and I am a user of Revit software 2024. I am reaching out to you because I am having trouble finding the structural connections in the software.
I have searched in the software itself, but I couldn't locate the feature. Additionally, I also extensively browsed the internet as well but it seems to be missing there as well.
Could you please assist me in finding the structural connections in Revit software 2024? I would greatly appreciate
Replies (9)
Message 2 of 10
jay_colc
Steel Tab > Connections > Arrow in corner of Panel
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 10
adigasbhavana21
Hey.. Thank you for your reply. But I'm not able to find anything under
Steel Tab > Connections > Arrow in corner of Panel.
Im not sure what content library I need to download to get those missing connections.
Thank you
Bhavana S Adiga
Message 4 of 10
jay_colc
You need to install the library content to allow the steel connections to work, also you may find you need to install the advance steel extension as well.
I seem to recall I had to do both to get the steel content working.
The steel connections in revit use a combination of revit and advance steel elements to create the connections.
This process has be the same for several years now, there is no change,  only they use a load of library models and Dynamo to create multiple instances of the same connection type.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
Jay Colcombe
Message 5 of 10
kadwadep
Community Visitor
Community Visitor
hello sir ,
i tried as you said above but it is not working.
Please help me. ASAP
Message 6 of 10
2141350047
Community Visitor
Community Visitor
Hello sir,
I have done all that step above, but I still couldn't find the structural connections in connections settings.
Could you please assist me in finding the solution? I would greatly appreciate.
Message 7 of 10
victor_vijeuKD42L
@jay_colc : That small button doesn't work for me either in Revit 2024.3. Standard steel connections are .rfa family files located in .../Families/Structural Connections/Steel/. It doesn't work for me because the are located on a common folder on te company server, not on my local machine. It seems you have to load those families in your project to work.
Update: I copied those families locally, still doesn't work. Maybe i have to install the Structural Connections package from the Revit install kit.
Revit Structure Certified Professional
Revit Architecture Certified Professional
Autocad Certified Professional
Message 8 of 10
jay_colc
One point to note here!
There are Structural Connection Families which are loadable families like any other Revit families and found in the Standard Families Library!
Then there are Structural Connections in the Connection Container that are generated using automated scripts that build the Connection based on input information and more hard coded and complex!
As regards your comment - That’s completely normal understandable as there is a default path location and if it cannot find them then obviously it cannot list or load them!  You can edit the Family Library Path in Options to the Server Location!
But for Automated Connections this may be different!
On the point of missing connection in the connection Container - Other have had joy installing the Advanced Steel Extension as it has lots of references in common and can be found in your Autodesk Account
Jay Colcombe
Message 9 of 10
KotairaKeila
Please, follow these instructions here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Download-the...
How to download the Advance Steel Extension for Revit
Advance Steel Extension for recent versions of Revit can be found here:
  1. Go to your Autodesk Account​​​​​​.
  2. On the left side, select "All Products and Services".
  3. Select "Revit" product.
  4. Select the desired version.
  5. Select the tab "Extensions".
  6. Scroll down to select "Advance Steel Extension for Revit [version]".
  7. Download it.
Note: An account admin may need to allow access to the extension: Assign product access
Message 10 of 10
nainamohamed2829
Observer
Observer
I have installed the Steel Connections add-in and all related components; however, I am still unable to find any plate families available for import. I have also attached the file path for the Steel Connections folder, but it appears to be empty.
Kindly assist if anyone knows how to resolve this issue.
