Structural Truss Display Option
JFN_KSH
JFN_KSH
I've created a custom truss family. My problem is that I can't change the display visibility of the truss in my Graphic Override... Does not seems to do anything at all... The only way the change the line graphic is to select individual structural component & override the line setting... Kind of tedious & not very productive... Am I doing something wrong? Suggestion?
Revit_Whisperer
The category you would need to override is the Structural Framing sub categories in order to change the color/line weight of anything in the view that falls under that sub category.
JFN_KSH
That'it!! thanks a bunch Revit_Whisperer!! You've just won some Kudo!!! It's hard to wrap your head around all the possible way Revit does thing...
Revit_Whisperer
=)...Happy to help!
