linked IFC window door opening box
Karol_Piroska
Advisor Advisor
Message 1 of 8
Karol_Piroska
Hi guys,
I wonder if anyone came across this. When I link an IFC file, there are "void boxes" within doors/windows (EDIT: within most windows and doors although all are same families). When I open the IFC directly in Revit or other application all appears fine.
(Revit 2018)
Capture.PNGthanks
Replies (7)
Message 2 of 8
Revit_Whisperer
What program was the ifc file created from?
Message 3 of 8
Karol_Piroska
This one in Revit but I have one other that was created in some different application. Previous version of same however didnt show any of these. I simply reloaded new versions of each and this is what I get. And again it is not shown on all openings, some are just ok although same family was used to create doors and windows.
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Karol_Piroska
Please check this article for workaround. (4th point in Workaround)
Rafal Gaweda
Message 5 of 8
Karol_Piroska
Thanks Rafal and sorry for late response.
Yes that could work, unfortunately I couldnt do this each time I receive a new model (very 2 weeks)
Message 6 of 8
Karol_Piroska
another issue I found is that while it is possible to switch off these void boxes in a 3D view (Generic models/ifcOpeningElement), same does not work in plan view. They need to be manually deleted from the linked model or manually select each element and hide.
Message 7 of 8
Karol,
I have not been able to prevent these openings from exporting from Revit either. I have tried editing the import and export settings for IFC with no luck. I have also tried manually editing the IFC text file to remove the openings (i only accomplished preventing the walls from being cut).
What I have done as a work around is create a filter that filters out all ObjectTypeOverride that does not equal Opening.
I check the filter off and select all the voids/openings in the project and delete them.
Message 8 of 8
Karol
Thank you for figuring out that this phenomenon happens within linked IFC's and not when you open an IFC.
