Hi!
Hi!
1-I wonder how to change the color of Structural Steel Connections?
2-How to create connection structure schedule such every connection com in schedule (Bolt,Plate etc)
Regard
Solved by Jason_Hagen. Go to Solution.
Solved by mihai.sandu. Go to Solution.
Solved by Nissar19. Go to Solution.
Hello Nissar,
For the issue with changing the color of Steel Connections please read the following forum thread:
In Steel Connections for Revit 2018 you can't create Bolt Schedule, Anchor Schedule, Plate Schedule...etc. This are components that are not separated in the connection geometry. You are not able to select them individually, because of this you are not able to create individual schedules. The only schedule that you can create is a Connection Type schedule.
We are working to change this behavior in a future version.
You can take a peek to the new Steel Connection features in the Revit Preview Release.
Hi mihai.sandu!
Unfortunately I can not change color the Structural Steel Connections the way your explained.
I want change color of bolt and steel plates
Regard
explanation
Hello Nissar,
I created a movie and uploaded it to the following location:
Hi again Mihai Sandu!
I wonder if you have opportunity to watch video, it possible to get Bolt anchor in schedule
https://www.youtube.com/watch?v=HFL-YH4sFK8
Hello Nissar,
In Steel Connections 2018 the user is not able to create schedules of the individual parts of the connection. The connection geometry is created as one piece.
We are working to enable this functionality in a future version.
To clarify, I was using the structural connections for base plates on my columns. Is there any way that you can get all the edge distance parameters to schedule out in a column schedule automatically?
Hi Jason,
When you say Edge Distance Parameters, you mean the parameters from inside the Connection Properties Dialog?
That information can't be displayed in schedules.
Yes that's what I was wondering. I was looking to try automate those dimensions and bolt sizes etc into a column schedule along with the column. Now that you can't do that, no need for me to waste anymore time. Thank you.
