Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Structural Steel Connections in Revit 2018
2 REPLIES 2
376 Views, 2 Replies
what add in do i need to load in these connections rather than as components?
2 REPLIES 2
Revit_Whisperer
If you are referring to the Autodesk Steel Connections that is a subscription add in found on the subscription site...if you sign into the Autodesk Desktop App on your machine it will likely also show up there if not already installed.
Once installed it will add a Connection Panel to the structural tab
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
in reply to: Revit_Whisperer
thank you for your help.
