Structural loading plans linked with loads
Is there a way of linking your structural loading plans to your loads whereby if you change your loads the loading plans automatically change ?
dzanta
If your Loading Plans show the loads for each member as an Instance Mark Tag for each load for each member (i.e. load at each end of a beam will have two Instance based load tags, one for each end), then the parametric information within the tag should adjust when your load changes on the member.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
