structural framing SHAPE HANDLES disappear when a modification or connection is made. Why does this happen?
djn9SY84
djn9SY84
Shape handles disappear when i make a modification to a structural framing member.
Why is this? Can this be changed?
I have attached some screen shots below explaining the problem i am facing.
Image 1
The shape handles have disappeared from my beam. This occurs when i make a modification or connection to the other end of the structural member. in this case i made a contour cut at the other end shown in image 2.
Image 2
Contour cut at other end.
Image 3
An example of what the shape handles should look like.
robertwmerriman2
Hi @djn9SY84
This is because a connection or anything from the steel tab changes the behaviour of the section into a steel fabrication format. Eveything about the steel fabrication format can be found in this help page - https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-8381A08F-CBCD-4215-AB36-82648C07B8F6
Rob Merriman, AEC Technical Lead, Graitec
djn9SY84
AH, Thank you very much.
