STRUCTURAL FRAMING MEMBER NOT SHOWING UP IN DETAIL VIEW (PLAN ORIENTATION
Hi All,
This is an old issue with a new wrinkle...
I have a HSS structural member that's not showing up in DETAIL VIEW even though I'm cutting well above it:
In the DETAIL VIEW, the HSS member only displays in REVEAL HIDDEN mode (can't unhide, not hidden). The HSS member is displaying properly in all other views.
There's no filters and the view template has visibility turned on for all families. Detail level is Fine. tried messing with the view range...no avail. Anyone got a clue?
Turn the discipline to Coordination.
ennujozlagam
@Anonymous check your phasing and @Anonymous suggestion. thanks
@Anonymousarjay.eco Nope didn't work....I tried "show hidden lines" by discipline as well.
@ennujozlagam Messing with the Phasing didn't work either.
@ennujozlagam @Anonymous thanks for the suggestions! The issue was the type of "structural usage" in properties window. The view template had "other" unchecked under Structural Framing Family.
A_MAQ
what is the category of this element,
did you try to change the detail level ?
Autodesk Expert Elite
NimeshJ
Hi @Anonymous , Can you check your Visibility of the view in which element is not visible.
Look into Imported Category -> Imported Family . Check it if already unchecked.
