Structural Foundation Tag Visibility
anaszok12
anaszok12
Hi everyone,
I'm creating a structural foundation tag that shows the pile deviation value.  My aim is to control the line and label visibility based inputted value inside the project - if positive it will show the right/up direction and if negative it will show the other way around.
Upon testing the family, it has no problem to show the pile deviation value but I'm having a problem to connect between the value and visibility of family line and label. Please help me with this.
Cheers,
Anas
shefypattambi
Hi @anaszok12
Could you please check your Deviation X parameter type? it is showing as a Family parameter instead of a shared parameter.
Parameters in the host family can only drive value of Labels in the tag family.  So, if you create the arrows as special characters in Labels then you might be able to turn them on/off based on the host parameters values.
See example Revit 2022 file.  I don't have Revit 2021.
anaszok12
my bad, thank you for pointing out
anaszok12
Thank you for the solution.
I want to take it further by writing if statement in the formula e.g if Deviation X>0 then tick the visibility box. However, I hit a dead end considering Revit limited capability in handling parameter data type. The ways that i tried are-
1. Deviation X/Y type of parameter is text, then the if statement cannot be used. The other way around is by detecting "-" in the string but Revit is incapable of doing that.
2. Deviation X/Y type of parameter is number, then inside the tag label i can only display '0' or '?' and not empty space like a text.
Hence I leave the family as it is and scripted a dynamo graph to do all the ticking of visibility parameter.
