Message 1 of 21
Hi, is structural connection add-in only inches, or somewherre i could find metric system.
The structural connection addin should use the same units as the project.
There is only one version that handles both Metric and Imperial units.
Joe
Hi Kaspars
PLease take a look here:
http://knowledge.autodesk.com/article/How-to-set-iso-metric-bolts-in-Revit-2017-Steel-Connections
Additionally please take a look here:
http://forums.autodesk.com/t5/revit-structure/revit-2017-no-new-structural-connections/td-p/6273891
especially posts 21 and 20.
same issue I have. Don't have a clue. May be need to join answer day to ask why is not support metric?
Kaspars, ft4481102
Do you see anything BELOW "ALL" in connection definition? See screen shot below
Your screen shot should be welcome
Thanks Raral, I do realize that I can change to metric now. However, in 'ALL', I can not find any bolt size standard for New Zealand. Is there any way that I can add more bolts size and geometry by using NZ standard bolts? Cheers~
For now not possible.
We have Australia bolts, maybe they help: AS 1111 and 1252.
<Deleted>
Thanks Rafal.
I think you're right. AS1252 is the standard we r using.
Can I set the default bolts type to AS1252?
And how can I do the dimension from the centre of the bolt in an elevation detail view? (I can do in the section detail view)
Thanks.
Unfortunately not.
See first link in post 3.
Hi Michael. Thanks for your advice. how did you edit the connection to add some reference plane?
ok, thanks. But in 2016 how do you create the connection? Use steel connection tools?
The Steel Connections tool that is available in Revit 2017 is not family based- there is no option to edit the connection styles, except through the Connections Properties dialog.
However, you can still create family-based connections as you did in Revit 2016 and earlier, if you want to.
Joe
@MichaelWarwick7522 wrote:
I'm using Revit 2016, not sure if this is still true for Steel Connections in 2017. Once the connection is finished I click on it and then choose 'edit family'.
Before dimensioning change display to wireframe and you can pick the center point of bolts. After dimensioning return to hidden view. It's done.
