Structural connection metric system
kaspars
Message 1 of 21
kaspars
Hi, is structural connection add-in only inches, or somewherre i could find metric system.
Replies (20)
Message 2 of 21
Joe.Charpentier
The structural connection addin should use the same units as the project.
There is only one version that handles both Metric and Imperial units.
Joe
Message 3 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 4 of 21
kaspars
Unfortunately i could not find solution in given links. Bolts is only in Imperial system.
Message 5 of 21
same issue I have. Don't have a clue. May be need to join answer day to ask why is not support metric?
Message 6 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Kaspars,  ft4481102
Do you see anything BELOW "ALL" in connection definition? See screen shot below
Your screen shot should be welcome
Rafal Gaweda
Message 7 of 21
Thanks Raral, I do realize that I can change to metric now. However, in 'ALL', I can not find any bolt size standard for New Zealand. Is there any way that I can add more bolts size and geometry by using NZ standard bolts? Cheers~qquestion for structure connection revit 2017.JPG
Message 8 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
For now not possible.
We have Australia bolts, maybe they help: AS 1111 and 1252.
Rafal Gaweda
Message 9 of 21
Joe.Charpentier
<Deleted>
Message 10 of 21
Thanks Rafal.
I think you're right. AS1252 is the standard we r using.
Can I set the default bolts type to AS1252?
And how can I do the dimension from the centre of the bolt in an elevation detail view? (I can do in the section detail view)
Thanks.
Message 11 of 21
kaspars
Yes, i found, thanks.
Message 12 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Unfortunately not.
See first link in post 3.
Rafal Gaweda
Message 13 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Keep in mind that Revit is not a Steel Detaling software.
For detailing purposes you may use Autodesk Advance Steel.
I will register this for improvement.
Thx
Rafal Gaweda
Message 14 of 21
MichaelWarwick7522
To dimension steel connections I edit the family and put some reference planes in so the dimension lines have something to attach to. Also allows me to check the dimensions, the tool seems to create odd dimensions which look like it works in the old imperial units and then roughly converts to metric.
Message 15 of 21
Hi Michael.  Thanks for your advice. how did you edit the connection to add some reference plane?
Message 16 of 21
MichaelWarwick7522
I'm using Revit 2016, not sure if this is still true for Steel Connections in 2017. Once the connection is finished I click on it and then choose 'edit family'.
Message 17 of 21
ok, thanks. But in 2016 how do you create the connection? Use steel connection tools?
Message 18 of 21
Joe.Charpentier
The Steel Connections tool that is available in Revit 2017 is not family based- there is no option to edit the connection styles, except through the Connections Properties dialog.
However, you can still create family-based connections as you did in Revit 2016 and earlier, if you want to.
Joe
Message 19 of 21
MichaelWarwick7522
Wow. That is going to be a problem. I edit every connection generated as none have ever been exactly what we have needed. Looks like we have to build a connection library until AutoDesk fixes it (again). I had been really enjoying how Steel Connections in 2016 would get you most of the way there. Perhaps you should put 'ability to save Steel Connection as family' onto the development feature request list.
Message 20 of 21
nuno.pedrinho
Before dimensioning change display to wireframe and you can pick the center point of bolts. After dimensioning return to hidden view. It's done.
