Structural Columns not showing up in detail view section?
Message 1 of 10
Have two columns (channel sections) on either side of an existing wall.
Columns display fine in the elevation view and 3D view but do not show up when a section view is cut.
Elevation View:
Elevation ViewElevation View
3D View:
3D View3D View
Section View (looking down)
Section View Looking DownSection View Looking Down
 Section View (looking up)
Section View Looking UpSection View Looking Up
Bug or user error?
Thank you.
Replies (9)
Message 2 of 10
francfiles
Have you tried changing discipline to structural? if you have a linked model, try underlaying it too.
Message 3 of 10
Already Structural.
Detail View DetailsDetail View Details
Message 4 of 10
francfiles
also, check VG if the structural column is turned on..
Message 5 of 10
Updated previous post.
Thank you.
Message 6 of 10
francfiles
check if "structural columns" are also turned on.
Message 7 of 10
Edit the family and uncheck Precut... box.
Message 8 of 10
Sure enough that solved my problem.
Still don't understand why flipping the orientation would show the columns.
Message 9 of 10
mkennedy
An engineer pointed out another tech had this issue yesterday. Found the same, re would show up if section flipped, but seems to be related to where the far cut off is, ie the section has to go down to/through where the col starts.
Message 10 of 10
benschilders
If anyone has this problem, this solved it for us.
Have been struggling to find why our colums would not show up in detail views changing this setting made it work how we wanted it to
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
