Message 1 of 10
Structural Column won't let me cut it's geometry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi... I am having a problem cutting the geometry of a structural column. If I create a reference plane across some of my columns and try to cut the geometry, it cuts briefly but then extends back up to the top constraint level. This only seems to happen to certain columns but I've never had this behaviour before.
It seems that the "connections" add in is causing the problem as the columns concerned have a baseplate attached. If I remove the baseplate, the column will cut as expected.
Has anyone else had this problem ?
