Steel plate only visible in some views
So Ive modeled some steel plates using the fabrication tool. But the plates are only visible in some of the views I have despite several of them having the exact same view template. In the views where they are not visible they are selectable.
Things Ive tried so far: Structural Connections subcategories are all enabled in Visibility and Graphics for all views, detail level is set to Fine in all levels and the view range is far enough that they should be visible.
Ive attached a print of what I mean, these two views have the same view template aswell.
múinteoir
can you attach the project?
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
ennujozlagam
try to set view template to none and apply again your default template or it could be your view range and also check your phasing. thanks
