Steel Connection to concrete column
baraboutis
baraboutis
Hello, i am designed the connections for a fascade. As you can see i have created the connection between steel beam and steel column with the Single Tertiary Plate connection from the vault.
However i cant seem to be able to use any of the vault connections to do a similar connection between the steel beam and concrete column. Any ideas how to solve this? I can only imagine a custom connection as of now but that would be my last resort as it will cost me too much time to apply properly through the whole model.
jay_colc
It is the behaviour of the concrete column setting you need to change it to Steel in the Family for Non-concrete connections to work - I would duplicate it and reload it intro the model
Alternatively look at the Embedded connection options?
Jay Colcombe
Autodesk Certified Instructor
