Issues with Staircase Modeling
geteway2digitalindia
Message 1 of 10
I am trying to Model the staircase as per the draing shown; but I am getting the output as attached. Please guide me how to make the corrections.
Also how to attach railings later - I have deleted the default railings of the model.
Accepted solutions (4)
Replies (9)
Message 2 of 10
hmunsell
Use monolithic or Precast stairs....
Update....
if you dont want the angled tread, pick the run type option, duplicate it, set the Nosing Length to 0
Howard Munsell
Message 3 of 10
GREAT.....ITS WORKING
JUST 1 MORE CLARIFICATION -
ALTHOUGH I APPLIED THE SAME MATERIAL AS IN THE LANDINGS - "M25-SUPER" TO THE STAIRS THE APPEARANCE IS NOT CHANGING. I WANT IT SAME AS THE LANDINGS SINCE I AM USING SAME MATERIALS.
PLS ADVISE.
Message 4 of 10
hmunsell
(view in My Videos)
Howard Munsell
Message 5 of 10
GREAT - ISSUE RESOLVED
ONE MORE POINT - IT IS NOTICED THAT OBJECTS PLACED AT LOWER LEVELS - SAY THE REBARS IN THE PILE CAPS IS CUTTING IN VIEW THROUGH OBJECTS PLACED AT UPPER LEVELS - LIKE 1ST FLOOR BEAMS, INTERMEDIATE SLABS..... ie : HOW THE REBARS ARE VISIBLE THROUGH THE GEOMETRY OF THE UPPER ELEMENTS. GOING BY DRAFTING RULES FROM 1ST PRINCIPLES THE LOWER LEVEL VIES SHOULD BE BLOCKED BY THE GEOMETRY AT UPPER LEVELS.
PLEASE THROW SOME LIGHT ON THIS.
Message 6 of 10
hmunsell
select the rebar in the 3D view, pick the View Visibility States "Edit..." button, and set it appropriately for the different views.
Howard Munsell
Message 7 of 10
DONE...
Message 8 of 10
Now I want to extend the waist slab & merge it with the 1st Half Landing slab. I changed the slab thickness to 150mm. Please guide how to achieve this
Message 9 of 10
hmunsell
So far this one request has turned into 4 😁. Not a problem, I enjoy answering questions, but they should probably all be separate requests to help other people looking for similar solutions.
In the Revit Help, there are a lot of good resources on stairs:
There are many videos on YouTube on how to modify and manipulate Revit Stairs.
Howard Munsell
Message 10 of 10
GREAT SOLUTIONS
