steel connection revit 2017
when I add steel connection to a portal frame the sizes of girder and column turned smaller. I was wondering what wrong did I do and how to prevent sizes of elements to change.
Replies (12)
catalin_lang
Hi
What family of columns and beams you use?
Are you using "certified" families?
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Structural connections can be placed only on new structural framing families.
If you used certified families, have you been editing those families?
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-8381A08F-CBCD-4215-AB36-82648C07B8F6
Any geometrical modification of the certified content will be overwritten by the standard value, when a steel connection is placed.
catalin.lang
I did make some modifications to the sections and this is probably the reason for the change when adding the connections. so, what should I do? should I create new families from scratch for beams and cols? or export the whole structure to advanced steel then add connections?
thanks for your response.
catalin_lang
About "create a new families from the scratch" - Steel connections use only certified families. These kind of families cannot be created from the scratch because they are in relationship with Advance Steel database.
About "export the whole structure to Advance Steel" - this will not solve your issue. When the model will be imported into Advance Steel, it will map your elements to the ones from the database. Advance Steel database contains only certified elements.  If the profile will not fit with one from the database, Advance Steel allows the user to associate the element with one from the database.
This is a known limitation. I recommend using only standard profiles / certificates in your workflow.
catalin.lang
THEN THERE IS NO WAY TO CREATE A DETAILED STEEL STRUCTURE WITH COMPLETE CONNECTION IF IT IS NOT OF CERTIFIED FAMILIES SECTIONS EXCEPT BY IMPORTING THE DETAILS FROM AUTOCAD INTO THE SHEETS.
COULD YOU PLEASE ADVISE ME ABOUT WHAT SOFTWARE SHOULD I IMPORT MY STRUCTURE TO IN ORDER TO CREATE CUSTOM CONNECTIONS?
DavidEEP
I have the same issue. I can't undestand why!
I began a new project from my template and I deleted all previous structural columns and structural framings and I loaded the German certified families for those objects.
When I am trying to load a new column or a new beam, it turns that it has always the same size, no matter what I select to load.
It makes me crazy.
Could you please help me to understand where is the catch?
catalin_lang
Hi @DavidEEP,
Can you describe, step by step, what are you doing?
Thank you
catalin.lang
DavidEEP
Hi @catalin_lang
On the menu I click on Insert - Load Family  and then I select the German family directory and I select p.e. a steel structural column (p.e. an IPE 270 section). When I load it to my project I get some warning messeges ( The parameter ........ doesn't exist in the Family. It will be ignored.) All the parameter's names are in German, I am using an English version of Revit. All the parameters in the warnings are important parameters that describes the section (height, width, elastic modul, noiminal weight, flange thickness, web thickness and so on).
When I insert the column in my model and I misure it, it seems to be a column IPE 240 and not an IPE 270. How can I fix this?
Is the problem in the different languages between the used family and the default software language? How can I manage this?
Thank you for your help.
mihai.sandu
Hi David,
Your supposition that you are loading a German translated family in Revit in English is correct. In order for the steel profile to be correctly created the family needs to be in the same language as Revit.
If you want to use the European steel shapes, in English, you will have to install one of the following country folders: Belgium, Finland, Greece, Norway, Netherlands, Romania or Sweden.
Please see the following link for more information on the subject.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Mihai Sandu
Sr. QA Analyst
 HI
The add on does not work .I have uninstalled -installed it multiple times with no success.
Best regards
mihai.sandu
Hi Triantafillos,
I see that the button displays Greek language.
Can you expand the dialog, by pressing the "Show details" button? We want to see what is the error about.
Can you also tell us the Revit build, installation language and Windows version and language?
Mihai Sandu
Sr. QA Analyst
I want to Add New Size in .txt file. Can I insert data into a file? Can the program retrieve data to create a new type? Thx 😉
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
