Hello i just have updated to revit 2024 and i was working previously in revit 2023 i made a model in robot and
Structural analysis 2023 and i sent the model to revit 2023 and started steel connection modeling (platform beams - moment end plate connection) when code checking the connection and checking the design forces use load combination box (use the forces from the robot analysis) it had worked properly and same forces and moments from robot showed up in revit 2023, as well as it had ran the code checking report properly,
But when i upgraded to revit 2024 and robot 2024
I Started same procedure upgraded robot model from 2023 to 2024
Send model and analysis results to revit 2024
And model same connection for same member
Firstly it showed slightly larger design forces(these forces in moment end plate dialogue box,but when i show the moment diagram in revit 2024 it show Correct values,but this is not useful because the values which is considered in code checking is the rong values)in revit 2024 (hence robot 2024 and 2023 there design forces are the same) but it was increased in revit 2024
As well as the code checking for (platform beams - moment end plate connection) did not work properly
Thank you for your attention
Regards
