Steel connection between beam and column as fixed or Pin
How I can define the type of connection in steel structure projects, (beam-column) as fixed support and (beam-beam) as a pinned support in Revit 2022?
ArmanMargaryan
By fixed support do you mean moment connection?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
how to define the type of connection between these elements as I have attached in the photo?
ArmanMargaryan
You can use existing symbols in Revit (See Picture 1) or create new ones (See Picture 2).
I hope this helps you.
Please mark it with ACCEPT SOLUTION, if the above reply answers your question.
Arman Margaryan
Linkedin | Facebook
thank you so much
