I need help modifying a Steel Beam that Modeling in one of our projects. I need to cope the beam so It's cut and continuous similar like a joist extension. Try the cope but all it does is cuts the the beam around the main steel beam, so cope does not work for what I am trying to accomplish. I have posted some pics so you can have an idea what I am trying to do. One is the 2d a on I how it should look and pic from the model.
Any help will be welcome. thanks
Solved by Rob_Merriman. Go to Solution.
Hi @WEC17
In the Steel tab (in Revit 2019 & 2020) there is a function called Contour cut, this will allow you to sketch the shape of the cut you require, i have created a screencast, see below
Rob Merriman, AEC Technical Lead, Graitec
Thank you for taking time to make the video. I will try this tomorrow. I will let you know how it went.
Rob.Merriman
Here is the final Roof Framing after I modify the Beams. Thank you.
