I used the OOTB Monolithic Stair with the default 25mm Nosing Run Type
I duplicated the Monolithic Stair and renamed it to referenced slanted so it is now its own Type
Within that Stair I also Duplicated and edited the Run Type 25mm Nosing also to reference Slanted so again it is own Type
As you can see with BOTH Types the waist remains at 300mm so as previously suggested this possibly is related to the User-Defined Profile directly!!!
In the Run Type if you change the Nosing Profiles this still does not influence the waist
So I can only suggest it is related to the Profile Family or the dimensions are not correctly picking up the waist thickness - use the Tab Key to pick a node
Then the bottom underside face
Jay Colcombe
Autodesk Certified Instructor
