Split rebar automatically
TasnimTarannum
TasnimTarannum
Is it possible to split a single rebar or a set of rebars, like splitting each rebar exceeding a 12m length in a rebar set?
veasnakimbitus
Hi @TasnimTarannum ,
Yes it is. For revision 2024 below, you can use 3rd party plug in like Graitec (https://www.graitec.com/Help/PowerPack_for_Revit/En/#t=Split_Rebar.htm)
or SOFiSTiK (https://docs.sofistik.com/2024/en/reinforcement/cmdref/modify/split.html#split)
For revision 2025, it has its default (wait and see the release by April)
jay_colcombe
At this time it is not possible without an addin such as Naviate/Graitec/CADSRC3D /RebarCAD/etc.
The workaround is to create 12m lengths and use the Rebar Constraints Tool to lock the bar ends both to the Start position (or other bars/references) and edit the Constrain dimensions to suit.
Jay Colcombe
Autodesk Certified Instructor
rafaelPD66Z
In Revit 2025 now is possible to do exactly that, but has some limitations, See the video below
https://youtu.be/ixwwGAidzi4
