some numerical data was out of range? (and other issues!!!)
So, yet ANOTHER issue with Revit 2020 (what a ****ing surprise!)
This error (some numerical data was out of range) comes up when importing previously fine DWG's? The DWG is a simple floor plan with walls hatched. I've done this on numerous previous occasions without any errors but now Revit has decided to give me another error to deal with.
ANOTHER thing that has now started to happen is that the imported CAD files are not visible in some views and don't appear in the VG imported categories list? When the **** did that change? It was fine yesterday but today it's started happening?
WTF is going on at Autodesk? Why can't you fix this ****?
Another issue which needs fixing ASAP is when you add any sort of connection to a steel member it loses it's surface colour properties and I have to override the graphics of each member in each view. What a ****ing ball ache that is!
How a bout sorting out issues with current versions before trying to issue the next one, which will, no doubt, have plenty more **** ups for us to try to deal with!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Most likely dwg model is located out of Revit 20 miles limit
Geometry in the File Has Extents Greater Than 20 Miles (33km)
Rafal Gaweda
How would a building that's only 15m x 15m be out of the 20 mile limit?
Why would there be a limit? (I have no idea how this works)
I have done a lot of Revit projects in this way before and never had an issue.
Just another issue with revit to add to the very long list of frustrations with this program!
I'm sure in typical AutoDesk style they will produce a "work around" rather than actually fixing the problem!
