Hi Everyone,
Just a quick question to see if anyone has a good workaround or solution to a problem/issue I am having.
I have a complex structure with many sloping beam and columns, when I set my view to show the columns I see the whole column and not truncated at the bottom cut plane. Mean in Plan it look like the column is flat.
Is there a work around to 'cut' the column at my bottom view plane?
hi @Anonymous,
try to change you View Range.
hope this help you.
regards
Ver
Hi @Anonymous,
actually it's a famous bug , but you can change the detail level to coarse it will works.
best,
Hi virgilio_benedictos, view range does not help in this instance it's nothing to do with view range, but thanks for your feedback!
Other than changing the View or the Categories to Coarse, I can only think of adding Plan Region at the columns and change the Cut Plane to just a tiny bit above the base elevation.
