Announcements
Sloped Drop panel on a sloped Slab
Ahmed_Muharram
Ahmed_Muharram
Greetings
I want to add a sloped drop panel to a sloped Slab, unfortunate the Slab "STR Floor" don't allow following a sloped refence
I have also tried to slope the drop by arrow but I can't change the reference only i can change the offset inside the slope arrow which is very time consuming.
what is your ideas?
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
jay_colcombe
The Way i have achieved this in the past, select the Main Floor
Modify Tab > Clipboard Panel > Copy
Clipboard Panel > Paste > Aligned to the Same Place
Edit the duplicated slab size dimensions to those of the Drop Panel Element (it will use the same slope reference)
View the Floor/Drop Panel in an Elevation or Section view.then you can then either;
Use the Align Tool to snap the Drop Panel to the underside if the Floor Slab
or
Select the new Drop Panel and in the Properties Palette, adjust the Constraint parameters of the drop panel so that it is at the correct elevation in your model. (not as simply with sloped references)
Finally, use the Join Tool to combine the geometry of the elements if necessary.
Jay Colcombe
Autodesk Certified Instructor
Ahmed_Muharram
thanks Jay
It works with slope arrow using specify slope but it will take a lot of time to arrange the accurate position
will try to automate with DYNAMO.
BIM Manager
Edit the slab subelements.
