Sloped and Tapered Retaining Wall on Sloped RAFT with Varying Wall Thickness
I am working on modeling a retaining wall, and I encountered a challenge while attempting to create a sloped and tapered wall with varying thickness. The approach I’ve taken is to use the "Model In-Place" tool, specifically using the "Blend" option to define the profiles for both the base and the top of the wall. To set the working plane, I chose the sloped raft.
However, I am facing an issue where the extrusion is not coming out in the vertical direction (Global Z direction), but rather in the perpendicular direction relative to the working plane (Local Z direction).
Has anyone encountered a similar issue or know a solution to force the extrusion to follow the Global Z direction? Alternatively, if there’s a more efficient way to achieve the same result, I’d appreciate any suggestions.
Thank you for your help!
