Beam mirrored section
j_pawlowskiQ4YZQ
Message 1 of 9
j_pawlowskiQ4YZQ
Two beams with the same cross-section are placed in mirrored positions using 3D snap. When I attempt to mirror one of them to the correct position, it only rotates 180 degrees.
How can I properly mirror the section?
Replies (8)
Message 2 of 9
jay_colcombe
Mirror relates to the Workplane you are in and the Mirror line so this would influence the result can it be achieved by trying to mirror in a Plan View?
Try Setting a Reference Plane to the Top of the Beam prior to Mirror.
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
j_pawlowskiQ4YZQ
When I mirror in section view and set 180 in cross-section rotation parameter, the cross-section of the beam changes to the correct position. However, when I try to rotate it to achieve the correct curve orientation, it reverts back to the incorrect cross-section.
What’s more strange is that this issue only occurs with a few of the beams, not all of them.
Message 4 of 9
jay_colcombe
It could be a limitation in the Beam/Family where if orientated differently it cannot resolve the shape so reverts back.
Difficult to fully determine without the Beam for reference.
Jay Colcombe
Message 5 of 9
j_pawlowskiQ4YZQ
The family is in the attachment. I hope it will be helpful.
Message 6 of 9
jay_colcombe
It is definitely the way the Beam Shape works with the Mirror functionality and its relationship to how it was placed and the Level
I tried using the Array Tool Instead?  Create a Dimension to find the Centre Point > Radial Array Move To: 2nd Pick Start of Beam then End of Beam
Jay Colcombe
Message 7 of 9
handjonathan
Hi @j_pawlowskiQ4YZQ
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 8 of 9
j_pawlowskiQ4YZQ
This works.
1. create beam in any possition
2. create arch in correct start/end orientation
3. Align
Thanks a lot for help 😄
Message 9 of 9
handjonathan
Amazing @j_pawlowskiQ4YZQ Glad you got it all sorted.
Jonathan Hand
