To hide part of a model in 3-d view, you can use the Section Box. In the view properties of your 3-d view, under the "Extents" section of Properties dialog, the you can check the section box (to see it, "Crop Region visible" must also be checked.) You can adjust the Section Box using the handles in the center of each face.
Joe
