Sheet - "Type Name"
Sheet - "Type Name"
396-78878892
Observer Observer
Sheet - "Type Name"
396-78878892
Observer
Observer
at same stage in my project, sheet parameters "Type Name" and "Type Id" have changed (I don't know how and when exactly it happened).
Now I have in Sheet Properties text "Treppe 07..." - see image below.
Is there a way to set it back to default value?
Norbert
My suggestion would be to load a new sheet to the project that has the correct Type Name and Id, you can then select the incorrect sheet and exchange it using the properties dropdown.
Once all sheets are replaced with the correct one, using the families section of the Project Browser you can delete the incorrect one.
Observer
Observer
Hi KM_Springfield,
thanks for your solution. Unfortunately after loading of a new sheet to the project (correct one, without any Type Name) the Type Name appears in the new loaded sheet as well.
Norbert
Not an expert on this but when I select the title block and then click on "Edit Type" I get the "Duplicate" and "Rename" options, do you not get that?
Note: If the title block is not selected then the options are greyed out
Greyed out if title block not selected:
Options available if title block is selected.
Observer
Observer
Hi
I get that as well but this doesn´t allow me to change/remove the description which appears under the word sheet when nothing is selected.
Is"[cid:image002.png@01D1CC72.607E6810]" the text Treppe 07..." appears for all types of sheets.
should be "[cid:image003.png@01D1CC72.607E6810]"
Norbert
Sorry out of my depth here - I cannot seem to re-create the problem you are having, hopefully someone else will be able to help.
