shared parameter, and stop connection between components
husam_al-jawhar
husam_al-jawhar
Hello all,
I hope you are doing well. I have two inquiries.
First, I made the sheared parameters as the project requirements, and each column must have its own parameters, but when I started adding the value to the column, it appeared that all the project's columns took the same values. How can I make each column unique and have its own shared parameter?
The second inquiry came when I took a simple example of two columns and one beam using a precast column and precast beam family. Then, when I started moving the column with the tool I created, the beam still connected to the column and expanded. How can I stop this connection?
Best,
Ahmed_Muharram
for the first part you should use instance parameter not type parameter.
I think that if you snapped on the column it will automatically move with it you have to draw with distance to the column
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
husam_al-jawhar
Thanks for your answer.
