Section Arrow Family with
Message 1 of 14
Can anyone make like this in Arrow Section family
Replies (13)
Message 2 of 14
ennujozlagam
@Anonymous  hello, once you drag your section view  in your title block (with drawing number ) it with come out automatically with reference number. thanks
Message 3 of 14
A_MAQ
do you mean like this ?
Autodesk Expert Elite
Message 4 of 14
I think he means when the called out views and the parent view are on the same sheet, the Sheet number in the call-out is replaced by a "-".
Message 5 of 14
Nope - It is on the same sheet and our standard if the section is on the same sheet number it should be " - " just like a straight line in figure image I attached, not the sheet number , I try to modify the family section, it work but when I open the file again the " - " is missing
Message 6 of 14
@Anonymous
You need a different Section View Type, using a different Section head symbol, where the Sheet label is omitted and replaced with a line.  You would have to manual select the section lines and change to this type where applicable.
Our AutoCAD convention is the same way but I have convinced the management to abandon it when using Revit.
See attached Revit 2017 file.
Message 7 of 14
I made that before but once you open the file again the line is missing
Message 8 of 14
What did you make the line with?  You cannot use Text.  It has to be an actual line.
Message 9 of 14
I try line and text not good you cannot rotate
Message 10 of 14
Open my file and copy the line and paste to yours.
Message 11 of 14
PrathapSekar
Hi @ToanDN
While select the line you have created is shown Rotate With Section check box as greyed out in properties pallet. How you did that, or have you simply copied the middle line? Also I cant see that option whenever I try to create a line in section mark family.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Message 12 of 14
I copied the middle line.
Message 13 of 14
PrathapSekar
@ToanDN,
How to get the option "Rotate With Section" check box for elements which we create.
Message 14 of 14
Cannot.
