Reinforcement In Ramps.......?
goswamig315
Message 1 of 14
goswamig315
can we provide reinforcement details in revit structure.......if yes then please tell me procedure of it or any tutorials because i will try it since 1 month any i can't get it..............so please give me solution of it.
Replies (13)
Message 2 of 14
-FDC-
It is possible.
What do you have so far?
Maybe you can post your file.
Message 3 of 14
A_MAQ
Ramps and roofs are architectural elements and cannot host rebar. To do this, I would recommend you draw them as floors.
Autodesk Expert Elite
Message 4 of 14
goswamig315
SORRY BUT IF IT IS POSSIBLE THAN PLEASE GIVE ME  ITS PROCEDURE.............
Message 5 of 14
-FDC-
I model my ramps as an in place component (or as floors like @A_MAQ mentioned before).
But it all depends on the complexity of the ramp, that is why I asked to post your file (or a screenshot of the ramp).
Message 6 of 14
yup
Message 7 of 14
goswamig315
I AM STILL WAITING FOR PROVIDE REINFORCEMENT IN RAMP....!
Message 8 of 14
múinteoir
Create the ramp in place, assign structural category then use the reinforcement tools to add the rebar. Its hard to give a procedure of you have provided no into in the type of rebar layout required.
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 9 of 14
sauradiptaneogi
I Will try to long time for same problem
Message 10 of 14
sauradiptaneogi
Reinforcement For Ramps ?
How to make longitude rebar in Revit for ramps with staggered
@A_MAQ , @múinteoir , @Anonymous , @-FDC-  Please suggest.  🤔🤔🤔
Message 11 of 14
sauradiptaneogi
A_MAQ , @múinteoir , @Anonymous , @-FDC- ,After create a ramp by floor , how to make longitude rebar in Revit for ramps with staggered ?
Message 12 of 14
sauradiptaneogi
@A_MAQ , @múinteoir , @Anonymous , @-FDC- Please suggest ASAP.
Message 13 of 14
sauradiptaneogi
If anyone know about problems .
Message 14 of 14
RPTHOMAS108
As of 2024 version I believe that ramp still isn't a rebar host.
You can convert the ramp to a floor quite easily (with variable layer thickness or not). Therefore I would use floor instead.
