SDS/2 Import to be Exported as .NWC file through Revit
I'm stumped on how to proceed or how to properly convert my SDS/2 Import into a .NWC export.
The steps I've taken are thus:
1) Export the entire SDS/2 Model as a .DWG (AutoCAD Version 2018, By member)
2) Create new Revit 'Model' through the Structural Template.
3) Import the .DWG export via Insert > Import CAD (All default selections except Place at: Level 1)
4) Modify the default Structural Plan(s) level to the 100'-0" level our model is set to so the model is visible in floor-plan view.
The support page suggests running Add-Ins > External Tools > Autodesk Navisworks but my only options through the drop down is:
• Multiple paths
• One Way Indicator
• People Content
• Create FilledRegion with a FillPattern
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
What about importing this dwg directly to Navisworks?
Rafal Gaweda
