Schedule Survey and Base Point Information
joseph.barberV526R
joseph.barberV526R
Is there a way to schedule both Survey and Base point Information? I am looking to create a simple schedule that will calculate the difference between the two Elevation Values, so we can use that figure in a Calculated Parameter for a Framing Tag for Top of Concrete for Upstands and Parapet Walls in plan view. Is this possible? Struggling to find a way to do this.
Mohamed-Nassar
you have abuilt in parameter called Top elevation and bottom elevation in each single structure framing element
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
joseph.barberV526R
Top Elevation does not show the correct output if a beam is offset from Z
