Rotating a group of objects creates unallignments
I am hoping someone can help me with my problem. We created our models based on different origin information then which is used in the later part of our project. The wrong offset in N/S and E/W coordinates I can fix with shared coordinates, the problem I have is with changing the Angle to True North in the shared coordinates method.
The angel is currently 286.387° which has to be changed to 286.368° (which happens automatically when acquiring coordinates when setting up shared coordinates). However when it changes te angle it rotates my object models with it (which it should) only during the transition from the old to the new angle not all objects in the project are rotated correctly, it creates an offset.
So when after changing the True North, I specify the coordinate at the top left part of the model. The lower right part is not at the correct coordinate anymore.
Does someone know a fix for this? I tried grouping the model objects, hoping they would rotate as a whole, but it didn’t work.
ennujozlagam
@Anonymous have you try to go to your site plan and rotate your model "rotate true north" thanks
