revit version
revit version
A_MAQ
Advisor Advisor
revit version
A_MAQ
hello all,
how can i change revit file version 2015 to revit file 2014
thanks in advanced
Autodesk Expert Elite
L.Maas
In short...you can not. Revit is not backwards compatible. As soon as a Revit file is opened and and saved in a later version, earlier versions will not be able to open it again.
The only possible route would be to export it to IFC and import the IFC in the older version. However you will loose all the parametric stuff.
Louis
Please mention Revit version, especially when uploading Revit files.
